91 stock auto tranny removal and re-install... TIPS anyone?
Hey Everyone,
Noobie here... let the questions begin.... :?
I just bought a 91 auto wagon with 165k miles on it and the tranny is slipping...
I've drained and filled the tranny twice with honda atf(old fluid smelled okay by the way) and it still has slipping when shifting from 2nd to 3rd, and clunks from D to R, and from D to other gears as well...
I bought a 'low mileage' (so they say) used one from the wreckers and wanted to know if those who have done this have any helpful hints.
I have a helms manual for the wagon and it says that when removing the transmission, part of the exhaust needs to be removed. It also says that an engine hoist is needed to lift the engine up slightly after the tranny mounting bolts have been removed to remove the tranny mounts, amongst other things.
Does anyone who has removed and re-installed the transmission know if these things are true and what to look out for when re-installing the tranny as well...
Thanks in advance!!!
Dave
Dave
Good advance notice about the oil draining after removing the drive shaft
I was hoping to avoid dealing with those exhaust bolts as I know they seem to be 'fun' to remove, but it's all good, as long as I can get them off...
I have access to an engine hoist, so I guess I'll be taking advantage of that...
I'll see what happens, hoping murphy and his laws have taken a vacation for a while....
Dave
Read the Automatic section in this link:
http://www.hondacivicwagon.com/board/vi ... .php?t=103
Oh, and earlier, I found a drain plug when draining and re-filling the tranny, twice, to see if it was poor fluid or incorrect fluid level causing the slippage...
Is there another drain plug??
I thought AK_CRX might have been referring to any tranny fluid that might be left in there after draining... I dunno... but I'll find out soon enough...
Thanks!!!
Dave
First, make sure you have the car high enough to actually get the trans out from under the car. I've made the mistake before on an accord.
I changed out a manual before and didn't remove the exhaust at all. It might be in the way or it might not.
Suspension, unbolt the swaybar links and the inboard side of the lower control arm. Turn the steering wheel to the opposite side you're working on and push out on the whole suspension while you're popping out your axel. Leave the axel in the hub and use some machine wire to pull it back and up out of the way. If you feel the right side will be in the way, undo the strut and pop the whole thing out of the way.
Remember, the less bolts you remove, the less chance you have of breaking/stripping bolts.
It says something about throttle cable too long,throttle B valve stuck ,throttle cable adjustment & contrl valve stuck.
SiWagon, I haven't checked out the troubleshooting section... yet. And, if it's just cable, control valve, or otherwise related, and not full tranny related, I'LL TAKE IT!!!! haha...
I really got the helms for the purpose of r and r of the tranny, but it it can save me from r and r'ing the tranny, worth the price of admission... if not, well, I'm sure it will be just what I need when laying underneath the wagon at 3 in the morning, haha, well, maybe a beer at that point, but it's a close second...
Thanks guys!!!!
Dave
By the way, did you replace any of the seals before you swapped in the 'new' tranny?
The ones on my JY tranny seem ok(no signs of previous leaks) but who knows what was done to remove these from their donors and I might as well since it's out anyways,
Thanks!
Dave
Possibly not having to remove rusty exhaust bolts... that would be nice, indeed!!
Most certainly going to do the diagnostic checks to make sure the tranny is gone... but I'm not holding my breath for that... just hoping...
Thanks!!
Dave
Oops...Forget the ramps :oops: it was 2 jackstands under the frame(behind the front wheel wells).
1 floorjack w/block of wood under the oil pan & the other under the tranny.
I'll be checking the 'blinks' for troubleshooting purposes this weekend but I'm not going to be doing any pressure testing as per the manual, and who knows, it might be something easy.... yeah sure it will... haha
Thanks!
Dave
yeah, just scoot it over into the floor beside the car
lol, just thought I would check
sorry...
But seriously, good advice... and much appreciated!!!!
Thanks!!
Dave
