Door trim inserts
Anyone pulled the door trim material inserts out before?
Just planning some things and was wondering how the are attached to the door card?
door trim material inserts ???
Got any pics of what you mean ???
But on the door card the material insert above the arm rest. Where the window controls are
Ah, see what you mean...
The material as opposed to the vinyl... gotcha !!!
I would imagine this is glued on. I have a couple door cards pulled out of my parts car so I can have a look tomorrow evening.
Cheers !!
I have a feeling it is glued also, I dont remember any clips or anything last time i had them off.
I would go pull mine off again, but if you have a one lying around it would be awesome if you could check.
Ya, I've got two door cards pulled off right now, including a damaged one which I'm going to have a go at removing the material from. I'll post pics of my attempts tonite.
Cheers !!
That makes it a prick of a job to DIY retrim them then
Did not take pics but, ya, it is glued on there real good !!!
It will be PITA to remove the material and glue something else in its place.
