Transmission LEAK... Need Help
Well, I got my tranny in my 88 4WD but it leaks from what I can see, the
right side axle where it connects to the tranny.
I thought it was the Out put shaft seal (Axle Seal). So I replaced that but
it still leaks. I hope that it is not going to be the tranny or expensive
because I just put this tranny in.
Can anybody help!!!!!!! Let me know.
I'll check it again tomorrow and post an update with pics.
PS,
could be worse ya know, could be a rear main that you just replaced and that one is now a leaker
Thanks for all the info. I didn't even think about all those things to make a seal go in easier. Good info.
I'll make sure I'll use those ideas for the future.
Here's a pic:
This is the spare that was on my old tranny that I took the screw from.
Here is the screw, spring, and ball that was missing from tranny I got from the junk yard.
Well, I finally got it fixed and having fun driving the car.
Thanks for the help/ideas guys.
I was driving to work and when I went to step on the clutch and I hear a
Click then the freakin clutch just went limp. Yeah......
So I pull into the middle lane and pop the hood and tug on the clutch fork
and it is just loose, I could lift it up and down with no pressure.
I'm hoping it's just the TOB...
If anyone gots any idea that would be great.
In the mean time I will be pulling the thing apart for the second time.
hopefully I can just swap it over.
Do you guys know why this happens?
Just curious, because I put in the new TO bearing and had a hard time puting the spring on the TO bearing but finally got it on. Hmmmmm....
pressure plate I got off of ebay. The fins where the TO bearing pushes
were stuck down not engaging the clutch. So I threw that out and put in a
pressure plate that was lying around.
One side of the TO bearing spring was broken too so I switched it with one that was lying around.
All this took me like 4 hours to take the tranny out and back in, mann.....
Well, I'll be putting in a performance clutch later when I get some more
cash.
I know I put in used parts but a running wagon is better than a dead wagon right!!!!!!!
tuff brake man, sorry ya had to go thru all that again.... and soon agian! tell you a word of advice, buy exedy they will never let you down. ever! plus you can go thru the different stages only to find a nice close to stock peddle. hope this will help for the future
