codes 7 and 14 on the ecu
my car is tellin me codes 7 and 14, the car starts and just dies after it gets warm, has a new dizzy,main relay,fuel filter and pump,
code 7 is tps
code 14 is idle air control valve
would these be causeing my car to just die like this or would it run but really shity and a jumpy idle ????????
code 7 is tps
True, but you can plug them in to each other even though they arent the same pin-out wise. Ive got those two plugs mixed up a few times. Then felt really stupid when one of our other techs walked up and pluged them into the correct spot and all of a sudden the car runs right.
If you havent had those unplugged latley, then Im sure thats not the problem. I did have my IACV go out on my Integra a few weeks ago, along with another guy I know with a 94 GSR. Mabie its that time of year???
