(coilover)spring rate question?
just got a used koni coilover. the spring rate on it way too stiff of me. Feel like I'm in a low rider
I did some research but don't get anywhere. Should spring rate be lower in the front? some web site recommend 270lb/350lb for street use.
what the different if the spring higher in the front? I know people do that for RWD car. but what about FWD car? should it be lower in the front?
And since I plan to swap the springs, anyone know the size of spring that i need, is it 2.25 or 2.50 :?:
front spring rate:
Lower=more oversteer
Higher=more understeer
Please do a search.Type in ''coilover spring rate'' under forum,''Suspension, Braking & Wheels''.Your answer is there.
thank
off the shelf Ground Controls (Eibach springs) come with higher rates in the front... something like 330/250
where is the bump stop on the wagon? is it on the shock or car?
I rise the high and it seem to ride smooth.
The rear DA shocks are taller by quite a bit, the fronts are very similar sized.
If you want the car to ride well, put the higher springrate in front.
SO is the shock still taller than EF shock?
good to info for the offroad wagoneer 8) was looking for longer front shocks that will go an extra 2" if possible, rear crx shocks just fine, they will go like 13" from side rocker to the floor, its just the front.
I got DA koni yellow on my wagon that why.
All the ef/da KYB and Tokico struts I have personally compared to stock were the same lenght. Thats crazy if Koni makes them longer. That makes no sence to me at all.
I will swap you for EF one
