Pulling Power (not a hith install question)
Under the bottom on my wagon near the bumper there is round piece of metal that looks like you could tie a rope to it and pull something, does anyone think that, stock, a wagon could pull like a road sign out of the ground
A road sign? Like a stop sign or something like that? I would say... most certainly.
HOWEVER, make sure your chain or rope is long enough so that the object you are hoping to pull out of the ground doesn't come down on your car. Also, make sure the rope or chain is securely fastened to the object you are pulling... nothing worse then having a go at it and having the rope or chain slip or pull right off.
BTW, I've seen dummies use a short rope or chain to pull down part of a structure, succeeding, and having the said structure hit their vehicle. :twisted:
