is possible to take rear disc brakes from a 87 prelude SI and throw it on a 85 civic wagon :idea:
na you want to find 86-89 teg and swap on the rear hubs/axle and dont forget the proportion valve, dont know about the awd model never done that one before
If you want the disc brakes for the back of your 2WD wagon, just swap over the whole rear axle and trailing arms from the 86-89 Integra. It's a bolt in, and you'll get the bigger rear sway bar from the Teg as well. It's housed inside the rear axle tube.
yes you only want 86-89 teg parts. oh and if you drop your ride you will need to make the panhard rod adjustable the more you drop the more the axle wants to swing to one side, its a easy fix.
i got the trailing arms and hubs
no axle (by axle i hope u mean the steel beam inbetween the two rear brakes) dont think i need them
i didnt think i would need them but well see wen i do the install
