S4 light????
i have a 89 RT and every now and then my S4 light randomly flashes , any help would be greatly appreciated
  • if you're sure it isnt oil change gear:
    http://www.hondacivicwagon.com/board/vi ... .php?t=738
    could be a faulty sensor
    didnt it occur when you bought the car ?
    did i say hi ?
  • the guy i bought it from , said it came on every now and then , when i first picked up the car it never came on , he also said it might be the switch on the auto stick
  • if your referring to that gear indicator light...
    i would check the knob on the shifter
    i had that also when i blew my headgasket
    that is exactly what i'm talkin about
  • i had that also when i blew my headgasket
    we have the same gearbox ...
    but then again i was cruising an average 90 mph for almost 4 hours
    on a hot day ... and yes, the kickdown will take it to 6000+ rpm
  • my car is runnin pretty strong for only havin 160xxx miles , i only run 80mph twice a day for about an hour and a half , i also have a pretty bad issue with my e-brake not wantin to release , any thoughts on that?
  • e-brake, ... could be anywhere in the line
    if it also occurs when you use the pedal, i would be worried ..
    sorry ...
    if you could be more specific about not wantin to release ...
    furthermore i have a really bad english technobabble ...
    learning
  • ok , here we go..........when i have it in park and i pull up the e-brake , it stays no problem , but when i start the car back up and go to leave , it is almost like i have a wheel chock behind the tire , i proceed to give it a lil gas and on one side in the back will kinda pop and settle then the other rear will do the same , then it goes fine
  • no funny smells, or noises ?
    shoe - replacement ?
    if braking does not feel feel like it should, it could
    be master cylinder
    i'll start cleaning aft breaks...easy and cheap
    if that does not work, go to front calipers
    but that is a different story, pistons and such
    sure i will be missing a point here or there ...
    take your pick
  • it is only when i have the e-brake applied , all other brakes work great
  • i'll start cleaning aft breaks...easy and cheap
  • my e-brake should be a cable(not fluid) right?
  • the last time i looked, in my car it is a cable ...
    summertime btw
    you think, -could have a rusty cable, not very common
    if you're a lucky you, it just could be a cable adjustment
  • it is possible , i'm gonna get under there this weekend , for right now i have just not been usin it , which i know is playin hell on my tranny
  • whaa, you have to wait, until we can sneak up on you
    to take pictures
    be good, have fun, keep smiling
    nice alienated topic in Electronics, Fueling & Air Conditioning
  • lolz , thanx for you help so far
