dizzy problems?
Ok i bought the wagon 800 guy said it runs well im driving home and if i try to go past 4000rpm it shoots right to like 6 like its slipping ok i finally try to fix this thou it was clutch wrong after replacing a fairly new clutch also put hx trans any way, it still the same thing so i said dizzy, bought one off a home boy haha and it was a little messed up well i did a almost full rebuild on this thing and cleaned it all and everything well it still dose it and some times it like gets stuck rpm's jumping a little and makes a funny noise.. anyone have a clue
Very confusing...but it sounds like the bearing inside the dist is going bad. Time to replace the whole dist as you cant just replace the bearing.
