power door lock wiring
sup fools. alright so i have been installing power door locks in my car for the past 7 hours. everything is in now its just left to the wiring.
the two rears only have two wires coming out of them, yellow/red and white/red. the drivers door has four, which all go into a door lock control box, anyways the only PDL wires coming from the drivers door are yellow/red, white/red and white/yellow.
the passenger door only has 2 i think, also same colors. anyways. so i am assuming that the two wires that are the same color all connect together. right?
and i assume the white/yellow wire from the box is the power source. right?
also there is an empty slot in the fuse box for power door locks... but i have no clue how to wire those into there.
i hooked the colors up and what not and hooked the white/yellow wire to another one but there is no reaction at all.
so anyways, the few of you that have done this.. can you give me insight? btw i used all OEM wire harnesses, etc.
can anyone link me to a sedan service manual that would have a wiring diagram?
I just added the same system to my 89 + oem 4dr pwr window regulators and switches
couldnt i wire the white/yellow just to another white/yellow? there was one coming from my stock door harness so i wired it to that but no go lolz.
anywho so yeah. how can i get that wire to the fuse box??
anyways yeah.
except along the way i think i fried something... my drivers auto belt doesnt retract. no matter what. the passenger side does, but the drivers is a no go.
can anyone point me to a wiring diagram of the seatbelt? i have been searching the web for the past 2 hours and cant ind anything :x this is really urgent, duh, as i cant drive my car like this
i checked all the fuses, they are fine. the power wire itself is not sending a current... so i hooked up a wire directly from the battery to the seatbelt power wire sensor thing and it still didnt do anything. maybe i fried the sensor? but why isnt the wire sending out current either? it looks perfectly fine, visually...
alright. cool. now im happy
