pedal assy. does crx/hatchback or sedan unit fit?
I'm gearing up for my Wagon's major transformation. It's of course going from auto to manual, so I need a pedal assy. I read this article...
http://www.gassavers.org/showthread.php?t=1033
which has some really good information about a/t-m/t conversion in an EF and this guy used a wagon pedal assy. in his EF sedan for whatever reason ( my guess is he just came across a convenient deal and figured it'd fit...)
Since the wagon unit fit his sedan, I'm speculating that a sedan unit would fit my wagon. There'd be a couple benefits to this. First off, the only junked wagon I have access to is at a redneck yard and they want $170 for it, or theres a junked sedan at my buddys house = free. Second benefit is the sedan has a shorter pedal distance from floor to engaged, and I have personally and heard of others having an issue with spot welds breaking/cracking on the wagons clutch pedal assy, obviously due to the pedal having more leverage on the structure. Me having a more firm than stock clutch in my previous wagon didn't do it any favors. I've also got a junk CRX in my garage that would be willing to donate if neccesary.
So, anyone know if they'll fit?
The other issue was the positioning of the clutch interlock switch- you would have to leave it off, if you care about such things. I ended up taking the sedan pedals back out and welding/reinforcing the broken ones.
