Luminescent Guages
I'm not sure if I spelled it right... anyways my guage cluster is on the fritz (the lights are started to dim) and I was wondering if there is a guage kit for the wago, I saw one here
http://cgi.ebay.com/ebaymotors/GAUGE-KIT-BLUE-GREEN-DUAL-LUMINESCENT-HONDA-CIVIC-88-91_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQitemZ120167592673
I probably won't get it off ebay, but it serves as an example as to what I'm talking about.
  • Wow...1997 called.
    This was one trend I wasn't unhappy to see die.
    The full face "indiglo" gauges were so bright, they messed with your night vision
    They never matched anything else in the interior
    It screams "I am an Ebay ricer"
    If you're dead set on doing this, at least get the "reverse indiglo"...only the numbers light up, instead of the full face
  • maybe 1997 should call, the economy would be better that way. (this is in jest btw)
    I'm actually not looking for the full on blue ones, it was just an example. Although I do want a bit of blue cause my stereo illumination is blue and I'm pretty much doing a blue theme
    Oh one more thing, the tach light is out (you know the needle) what would I need to get to replace it.
  • you could achieve something similar by just changing the color of the bulbs ...
    yeah, you've heard that before, i know ...
  • 949949 Senior Wagonist
    if you need a donor gauge cluster i have an electrical working cluster but the speed/mph side is not working and the temp is not but the other stuff is. let me know if you want it.
    the gauge clusters are the same for all ef as long as u stay year specific. Its very easy to just simply replace the burned out bulbs though... The needles r illuminated from the red glow on the top of the cluster, which glows from two bulbs.
    If you'd like I can also source oem clusters that work. Hell I've got a 200kmh one right here from Europe if you want :P
