All 2WD Wgn use the same axles.It's also the same axle used in all CRX DXs.
Sorta right... I had a HF tranny in my wag with the same axles I'm using with the EX sedan box I've got now, so I don't think THAT'S different.
I did see a different part# for 4 spd axles, though. Seems like I remember a different spline count...? I guess that means SiWagon's correct, there were no 4spd wags, just hatches, no?
Anywho... I've got axles, you need axles, the price is right. :P
Just a little side info, I wanted to switch axles of a 91 CRX D16Z5 engine with axles of a D16A9 (engine's are 99% the same). The outside end didn't match, the D16A9 were about 1mm bigger in diameter. So we had to swap out the end links of both axles.
Dunno if this will occur withe CRX axles on the Wagon.
+1. I did some research before buying my replacement axles, and 4wd is, indeed, 27 splines. No separate listings for manual or auto transmissions, so the axles will work with both, but they are NOT interchangable with 2wd transmissions. The 2wd models are basically a Civic DX drivetrain.
Bring your car over, we'll take out the old one and compare.
also dont think it mattersif its AT or MT
dunno about the 88's though, i heard they are different, different # of splines or something.
we only got the SOHC D15B2 and D16A6 :roll:
88's wont fit 89-91 because they have a different spline count. Honda seems to tend to keep increasing it by one or so every little while!
1988 Axle spline count: 25
1989-1991 Axle spline count: 26
25 is inboard spline count for all Wgn.
26 is outboard .
27 is 4WD inboard.
See link under ,'' axle shafts'' :
viewtopic.php?f=7&t=103&p=453#p453
