Codes... Location of these sensors?
6 - Engine Coolant Temperature
9 - CYP
10 - Intake Air Temperature
These are the three codes that i have.. Unfortunately i have no idea where these sensors are located..
Can anyone post a pic or give instructions as to where these are located? Then i can start testing them and the wiring.
The car is a '90 Shuttle RTi with DOHC ZC conversion, running a PM6 ECU which will be swapped out for a PM7 when i have the time and money.
Cheers guys..
9 - CYP
Cheers guys..
p.s. i was hoping you could help me find some jdm tail lights some time. thanks.
hope that helps. also i got the procedures to test those sensors. it is very detailed and has step by step. were do you want 10 pages of info posted at. i still need to scan the pages
No need to scan the 10 pages... unless you want to...
Ps how do i get the pix on my pofile and if i can change it to #3?
