go figure... crank pulley bolt blues
i knew it was coming... so im off to change my timing belt. got everything removed, like the engine mount and stuff. hell even the radiator and bumpers, etc for space.
well i come to the crank pulley bolt. i have my father put my car in gear and also step on the brake to loosen it. but the pulley still turns!! wtf? is my clutch slipping?! soooo that plan was ditched.
next we jammed a screw driver into the crank pulley against the block but it doesnt budge.
also tried Haynes suggestion of jamming a large screw driver into the flywheel ring gears. bulllllll idea whoever came up with that was on drugs.
so now, i am so efkin tired, had a total of 4 hours sleep for the past 3 days... and i dunno what to do right now. i drowned the bolt with WD-40 right now... gonna let it sit overnight. and now im just ranting but seriously, what should i do to get that f***er of?? car is completely immobile now hahaha
I know this doesn't help you right now, but it'll help someone that does a search in the future. In your case, you'll likely break a couple power bars if your extension pipe is too long. I know I've broken one or 2 in the past trying this exact thing. Watch the screwdriver through the pulley trick. that's a good way to break the pulley. The white metal cast ones will break apart in the area around the holes. If not, you're taking a chance of breaking a piece of your oil pump, as that is the part of the block that you're jamming the screwdriver into.
and the honda shop manual rates d16a6 it at 82 lb/ft
thanks for all the replies guys, really appreciate it.
What if it was a male bolt? VERY SEXIST OF YOU :evil:
This is exactly the kind of advice I LOVE to read 'cause it empowers me to try stuff as a "backyards mechanic".
let me rephrase... IT'S off.
and my car runs now. got everything put on and back together
lolz thats how it is right now :P just keep adjusting it a little each time i drive hahha
Adjust to MAX POWER then bring it down a notch! Thats how my timing was set. MAX POWER
How'd you get it off?
same here, i couldnt handle all the horses so i had to notch it down a bit. typical wagon syndrome.
like in that link i posted... i put two bolts across from each other into the pulley, then a crow bar in between them and rested it on the cross member. then i had my dad put his full body weight against the socket wrench and miraculously it broke free :shock: very happy, needless to say
this worked for me but I also used a jackstand right at the neck of the breaker bar to keep it's leverage. the pipe I used for added length was about 5 feet long. when jamming the screwdriver into the flywheel teeth via the starter location, I didn't just jam it in, I turned the flywheel and I looked for a beefy spot and then jammed the big screw driver right on a good angle where it wouldn't move under pressure..not all the spots on the flywheel teeth would hold it down I found, that's my method.
Ironically, a couple of weeks ago we pulled the dead motor out of my gf's CRX Si. Did it at a friend's shop. He handed me his 3/4" impact wrench and said "Here, make yourself feel better - go pull that crank pulley bolt." Less than 10 seconds with that thing did what 2 days in my driveway with lots of effort and swearing couldn't accomplish.
The CRX's timing belt was replaced literally a few hundred miles before it started clanking badly, so we pulled it to put on the replacement engine with a belt of unknown age. Actually, pulling that motor from her car made me a lot more confident about working on my own, being the same motor as my wagon.
Impact...
but ended up getting it with this method...
I think having that extension off the ratchet is the reason you twisted your bolt. I twisted 2 extentions that way. You have to get right on the bolt with the ratchet.
For all those saying that the impact is the way to go, sometimes even that isn't enough. I tried two impacts and neither did it.
Glad to see you got it off wagonDizzle. One screwdriver didn't work for me, but 3 did!!
When it comes down to it, the guaranteed way, is to lock up the flywheel, get an extension with a 1/2 drive on the end, put the socket right on the nut and whack it with a sledge hammer.
I just went through all this... \/
viewtopic.php?p=76798#p76798
John
