EXHAUST ROUTING
Does any1 have theirs exiting on the right? If so - did you cut a groove for the muffler tip?
Can you post pics on what your shop did about the rear, it's really hard to determine the routing I want for mine --- it's HIDEOUS. I have a good mind to fab up a side exit before the rear tires.
The previous owner on mine definitely has a ghetto setup --- I intend to remedy that before I leave Colorado this weeekend.
the header however hits everything.
which wagon did you get?
I did exactly as quarters said. Got rid of the restrictive 90 bend at the rear, welded on a 20 dollar fart can.
http://www.hondacivicwagon.com/board/vi ... ust+routed
{---} <wheels/trailing arm
Yeah something like that..
I looked into the Borla muffler that comes highly recommended from other members, but it was way more than the Magnaflow and two weeks out. I do wanna try one though...someday.
And just as a reference, if you use mandrel bends where you have bends, they are gonna cause a lot less restriction so you can use the stock route, unless you just want something different. I just like to cause less attention to myself from the local honda hating police.
what are those red things?
Nope, not in back. All that hits on the norm is the front of the 3' resonator. I hit the rear section if I angle my driveway wrong, but its not all that often.
Correct on the rear toe adjusters, the dual flux-capacitors were on backorder and Im impatient so I said screw it. Toe adjusters by Suspension Techniques.
