DX/DPFI techie needed (solved + pics)
have a missfire on the #3, changed the plugs, cap, and rotor; as well as the spark plug seals. wire is good, checked for spark. after fixing all this car sounds like it's running great, but it still has the miss...the assumption we are going with is something with the fuel system. anyone have any ideas? when we pulled the plugs 1,2,3 where dripping oil and #4 was WAY white. not familiar with the dpfi setup, help is greatly appreciated.
thanks
thanks
These gaskets:
http://bkhondaparts.com/billkay/jsp/prddisplay.jsp?catcgry1=CIVIC&catcgry2=1991&catcgry3=WGN+4WD+1600&catcgry4=KA5MT&catcgry5=CYLINDER+HEAD+COVER&ListAll=All&vinsrch=no&systemcomp=Engine&prdrefno=&quantity=0&act=&count=0&hidSwitch=Switch&hidIrno=%7C003
when we checked the injectors all the wiring looks good so we unplugged the harness from the top injector (brown) and nothing kept running the way it was. then we pulled the harness for the lower injector and the car immediately stalled out. assuming its a bad top injector, getting one from a friend to try and swap it out. which injector is the one that runs all the time and which one is the one that only comes on under load.
thoughts/suggestions?
Damn chunks of valves??? Did it just kick the pieces oout the exhaust or scar the cylinder walls?? Thats crazy that it just busted some pieces off.
check back for the pics
I give up, my eyes go screwy ...
o wait, the back end of a donkey, close up ?
