oil consumption/burning oil
I've got a 91 rt4wd with the d16a6. At the moment, it is burning oil at a rate of about 1.5-2 quarts every 500 miles or so. As a result of this, my tailgate is all black due to the residue of the carbon coming out my exhaust. There is also smoke coming out of the exhaust when I shift from 1st to 2nd or 2nd to 3rd. I can also smell either burning oil or exhaust when I'm driving with the windows down. That I assume is an exhaust leak somewhere up front.
I've searched and have come up with valve seals and/or rings needing some replacing. Does this sound about right? And is it a fairly simple procedure to do myself?
Thanks in advance!
Thanks in advance!
Bad valve seals make most of thier smoke on startup then the smoke dissapears untill the next startup, at least thats how it usually works for me.
Doh, thats what i was meaning - the spark plug hole seals.
your cam is a tooth off. my wagon runs so much stronger than yours and i think thats why. put it at top dead and check where the cam gear lines up. or a bent valve from snapping your timing belt at like 100mph
as for the burning oil, most likely valve seals, the main seal on the pulley side of your crank, or right below the distributor. I lucked out on my motor and have all three leaks YAY!!!! Three strikes your out, i actually have to get a couple of quarts of black gold before i go to work today.
