Driving problem on a 2wd
Long time reader, first time poster.
I have a 91 2wd and sometimes while I'm accelerating the car acts like I'm pushing in the clutch, but just for second. Its a wierd jerk feeling, its hard to explain. and at the same time I hear a click under the dash, like a relay or something. Sometimes it does this alot and then other times, not at all. I already checked the tension on the clutch, and I do need a new right side axle, but I dont see how that could have something to do with this. Any ideas would be appreciated.
-Jeff
-Jeff
When the car jerks - does it rev like you pushed in the clutch or does it sorta stall then pick up again?
I've had the problem with the relays before and its more like when you are on the throttle, the engine is being flooded but just briefly.
So do you mean that? ^^^
Or more like below?
If I'm cruising on the highway and push in the clutch the rpm's shoot up. Like what would happen if the clutch is slipped and the flywheel broke away for just a second before you let off the gas and let it "re-engage".
Main relays can be repared as well. Basically what goes wrong with them is a bad connect. I have a guy here locally that repairs them for 20 bucks. Do a search on Honda Tech. I think thats where he got the info. Im using 2 "fixed" main relays in two of my cars right now.
And it might be a long shot as to whats wrong with your car, but we had a thrust bearing go bad in our EX sedan. Took us a long time to figure out wtf was going on. It would try and stall out whenever you pushed in the clutch. Made no sence till one day Im under the hood telling my girl to press in the clutch when all of a sudden I see the entire crank pulley stick out and almost hit the framerail. Weird shit. That was a first for me.
Source one through Honda too, if its not that much more I would recommend the Honda relay.
