stainless brake lines
I'm about to change brake fluid, and thinking about upgrade brake lines at the same time. from looking around I hear you can use civic or crx lines but which one do I use? use the non SI one? What brand do you guy recommend? I'm thinking about getting russell line. any one know the part number of the one I need.
Thank you
Thank you
If you doing the fluid change you should change out the Master Cylinder for the 15/16 from a '89-90 Accord LXi or 90-91 Civic Sedan EX. I would recommend doing that before you do the lines. Lines are good but unless you have the rest of braking system "built", overkill for stock setup.
I used lines that were supposed to be for a crx on my 89 rt4wd. No fittiment issues at all.
