Dreaded rear clunk
So I am getting the rear clunk at almost every 1-2 gear shift. At first, it only happened every so often, now its all the time.
I was looking for threads on this, as I know there were a few, but I didn’t seem to find any with actual diagnoses. Was it the bushings for the rear diff, or something else all together?
Anyone with the rear “clunk” issue who has solved it, please point me to the thread or let me know what it was!
As a side note, depending on what this actually is, do I need to be worried about driving it around? I got a lot on my plate right now, fixing this wont be first on my list……
Are you talking about the one mount at the rear of the diff or the two mounts above the diff?
It's a really simple thing to do to replace this mount. I picked this up from Honda for $35. Just jack up the rear of the car, remove the muffler, then there is 3 bolts holding the mount on, a through bolt and then 2 bolts on the rear diff. It took me 30 minutes max and that was because I had to keep walking back up to the house to get fresh brewskis.
yes it was relitively simple. next time you have to have a what i call "tool bitch" a freind that hands you tools presses the brakes & gets you beers
I replaced the rear mount that you guy's are talking about (the old one was torn), and put a new one in. It still clunks but it's more of a thud now.
Any other suggestions to get rid of the thud? It's such a PITA, especially in 1st and 2nd stop start traffic.
TIA.
Where are the other two?
Oh, i've never noticed them there before... How would i best access them? remove the dif? does it bolt to the subframe?
