Replacement Fuel Pump
Scenario:
I was zipping along the freeway at 70 mph whn suddenly the car just started bogging down and losing power causing me to turn on my hazards and cruise to the far right emergency lane. Tried to start it but to no avail (all guage lights would turn on but the car would just keep cranking).
Status:
Just determined that my 90 Wagon needs a new fuel pump after following the step-by-step instrucions in the Honda Shop Manual. It instructed me to place a jumper wire in the Main Relay P-Connecter between the BLK/YEL wire and the YEL/BLK wire, then check if there is voltage coming from the YEL/BLK wire and BLK wire p-connector that plugs into the fuel pump - low and behold there is and the manual simply stated to "replce the fuel pump." Now I am asking how difficult is it to do and what replacement pump I should buy (NAPA and AutoZone has a pump only for $200 each).
Also, I heard of people replacing theirs with WALBRO's... Whatever your suggestion, part number and source to buy from, please...
Thanks in advance!
Tom
(213) 505-2500
Status:
Thanks in advance!
Tom
(213) 505-2500
oem fuel pumps are good and realiable only up too 200hp.
if its an old pump it wont flow that much.
walbro do have more juice flowing out of it but there are some history of it failing early. the occurance is very small but i has happend.
since its more performance related its also going to be a tad bit more noisy when its running.
depending on what your trying to do, you can choose either one. the price is somewhat close together.
