Cooling Issues!!!!!!!!!! HELP!!!!!!!!!
Going down the interstate my car starts running hot. (Not in the red, I see it before then) The temp guage will go a little under 3/4 way up and slowly fall back down. Then go back up, and then down etc..
If I clutch it and let off the gas, it will drop back down to normal, then when I give it gas it goes back hot..
I can turn the heater on and the temp will go down to normal but rise a very small amount when I gas on it.
WTF?
New Radiator Hoses
New thermostat (checked it by boiling water)
New radiator cap
Fans work correctly
Water pump working correctly.
Could it be in my radiator or my guage? I am throwing no CELs btw.
Note:
I suppose the water pump works correctly, I changed the thermostat and then let it run till all the bubbles came out, then out of nowhere antifreeze started shooting out the radiator cap hole like a volcano.. I suppose this was the water pump running/the thermostat opening.
So what do I go to check from here?
WTF?
New Radiator Hoses
New radiator cap
Fans work correctly
Note:
That or make sure thiers no air in the cooling system. My D-wagon has a bleeder valve on the upper rad hose housing on the head.
