found alternator wire melting?
just did a test drive today and found the white large power wire burning and melting. the wire is right at the alternator.
why is it melting right there?
is it because the alternator is going bad or is it because something is grounding?
i was starting to think it was because of something in the car is grounding but nothing new is installed recently.
also if something is shorting in the car would the wire melt at the battery, being that the wires are all fused but at the battery and not directly at the alternator.
any help is appreciated.
I only know of 2 or 3 grounds in the engine area.
I am no expert so I could be wrong
when i checked the volts i never saw 14v. i only got as high as about 13.6 while driving it fast.
is it something i need to change out?
13.6 I wouldn't worry about. From what I have read alternators should produce around 13.5 to 14.5 so I wouldn't worry that is if you aren't having any starting issues.
The shops like Autozone can test your alternator for you also just to make sure.
i thought i would just tighted it down and take a drive first before i do anything else.
well it seemed to help the power failer issue as the memory in the cars radio and such is much more stabilized.
so i guess ill just leave it for now, if it acts up again ill do more.
the idle on the other hand is still present. the symptoms have changed a little bit. it does not bounce as much. it just stalls out a lot when i let go of the gas now. start or warm ups are ok, very good idle during warm up. its just happens only if i give it a tad bit of gas. it just drops down and stalls out. i can make it stay at idle only if i let go of the gas pedal slowly. then it stay at about 750-900 rpm.
i just cant figure it out.
if i only knew enough about which parts do what and gives me this reaction i can then test that part out.
so far i have
clean aicv,
tested aicv to see if plunger moves when pluged up,
it moves,
new o rings on aicv.
cleaned fitv,
new o rings on fitv,
clean t/b
clean intake manifold,
new intake manifold gasket,
new tps sensor,
calibrated sensor .45 volts,
new pcv valve,
new fuel filter.
these are my new guesses:
i have a bad alternator,
i have a bad distributor,
if i know how to test a distributor that would help,
aicv is actually bad,
there is a leak but i still have not found it.
Anything over .5 AC volts is too much. If you are getting more than that there is something in your alternator failing..
You should be getting 12.4-12.6 DC volts when the car is off, and 14.2-14.6 DC Volts when the alternator is running...
Undercharging issues:
Battery-
Power or Ground Problem
Bad alternator
corroded or damaged battery cables
Bad voltage regulator
Abnormally high electrical demand
Loose or Slipping belt
Lucky for you I am studying charging systems at school right now..
i just replaced the alternator. no change what so ever.
i got the alternator tested and they say its actually still very good. so no internal damage to the alternator.
i was also told that the ecu might be bad.
so i guess the only thing i need to try is to change out the ecu and see what happens.
All you have to do is get a 3/8" (i think) hose and run from the outlet to the other outlet.
I do it when I replace my intakes..
Also,
I had a shop owner look up electrical diagrahms for a integra (my engine specs) and he said it looks like the alternator is case grounded to the engine.. This is probably the same as the d-series..
Was your new alternator painted? That could cause bad grounds..
I suggest sanding all your grounds down to bare metal, then re-attatch them, then cover them in clear silicone to prevent corrosion..
I just ran a wire from my alt case to my chassis and now I am charging correctly, as before I was getting 27 volts of AC current, and only 12 volts of charging power.
(I am having charging issues as well)
