(now i know)how to discharge the ac. thanks
i'm pulling the engine out of my 88 and it looks like i need to remove some hoses from the ac to get it free. checked the manual and it said "WARNING!! HIGH PRESSURE!! have a pro dishcarge the ac before unbolting anything!!!!"
can anyone tell me how to do this safely? i kinda enjoy life.
thanks
thanks
they have the proper gear ...
im not a tree hugger, as such
but you kill us all releasing that stuff...
no seriously, read first line
anyone else?
i know it's probably not the best eco move, but like i said, it can't move anywhere and it has to be done.
any help?
somewhere behind the battery in that section, in my eurocar that is ...
On other cars, I've simply unbolted the compressor from the block without disconnecting lines and set it aside while yanking the engine.
Otherwise, just follow the lines going into the evaporator - there's a shraeder valve on one. Just let it out like letting air out of a tire. Wear gloves and goggles if you're worried.
I'm no pro so my advice may suck = try at your own risk
i'm going to try to leave the compressor connected and just remove the hoses from the firewall if i can.
thanks for the tips
