spark plugs are electrical, so i'll post it here..
spark plugs & dizzy stuff are electrical, so i'll post it here..
do you gap your plugs? or leave it alone?
i bought some high end NGK platinums and i tried to gap em and it didn't look right.
also does anyone use an MSD distributer cap & rotor? any difference?
thanks.
An MSD cap will reduce resistance in your ignition system but will not make much of a noticeable difference. However the whole MSD system together (including leads, blaster 2 coil, cap and SCI) will make a small difference and allow you to do a number of things with the ignition system.
will those iridium spark plugs run your engine hot because you can't gap them?
btw, what is an earthing system? is it a waste of time and money?i don't see anyone with it, but i see a few jdm aftermarket companies make them..
Oh and as far as the spark plug matter goes, almost every spark plug I've bought in the past 4-5 years have all come pre-gapped to my car's specs. The only reason I say that is because the parts counter salesmen have told me they were and I personally have double/triple checked them to those specs. AND I have never bought a set of iridium since I went turbo.
i bought those iridium ones..cost me like almost $9 each!
i just don't want my engine running too hot since i'm not gapping them.
voila!!
i thought it was all the same.
do you happen to know which Iridium plugs work with the wagon? I just bought a set off the shelf and put them in.
Spark Plug Part No. Stock No. Plug Gap
Standard BCPR6ES-11 6779 .044
V-Power BCPR6E-11 # 5632 .044
G-Power Platinum BCPR6EGP 7088 .044
Laser Platinum BCPR6EP-11 * 3350 .044
Iridium IX BCPR6EIX-11 4919 .044
* Premium Laser Plug
# Original Equipment
Wire Set Part No. Stock No.
Wire Set HE53 9689
Is that the right motor for your car? Those are all the NGK plugs for that motor..
aha! yes i remember now..i bought these:
it says to gap them .044, but there's no way you can gap those little tips.
