rear side windows - replacement?
So the wagon I bought needs two windows replaced. The rear passenger door window, that will be easy. The other one is the drivers side window in the very rear. The ones on the sides at the very back. I found a replacement window in the wrecking yard, but is this something I can do myself or will I need it done professionally? Obviously new seal will be needed, but no idea where I go from there. I need to pick up a manual, which may explain it more, but just trying to get a heads up on this since I live in Washington and I need to get it taken care of sooner than later...
    I think they're glued in with urethane, just like the windshield. I would have a glass guy do it.... and I'll try nearly anything!
  • There is a spoon shaped util for this, work it around the edges
    think of bicycle, tyre, and fixing puncture ...
    you get the idea
  • same as windshields, i've seen people using a flexible wire saw that cuts thru the sealant holding it in place.
    I agree, i'd probably just let the Glass guy deal with it. Things like that are SOOOOO much easier for someone who's done a hundred times before.
