WINDOW - TINT - FILM ! i've choosen ...
basically here, this side of the planet, we're not allowed to do the front-section.
Rear section, no probs ...
i've searched, what's you guys using to tint, couldnt find any name, fabric or brand.
if there is al link on HCW, throw it ...
Coating is not an option, i believe in non-destructive modifications ...
No glue either please ...
however, they ALL use an adhesive glue to stick the film to the glass.
closeby there is a shop specialized in plastics ...
i'll go see what kind of temporarily stuff they got ...
thanks Pimp
if you are allowed to tint the rear windows, just get a professional to tint all the back ones with a nice dark film. once its there, you will wonder why you waited so long to get it done, adn you will never want a vehicle without it again.
coating involves a protective layer (film) to protect the coating
friend of mine had his 'tint' last week, very nice ...
regulations: no 'front' mods unless factory, 35% driver and passenger side,
no windscreen unless factory (stupid ey)
rear - allowed as much ... only one rule ... must have passenger side mirror
pimp: well the ac works so, but by experience i know its stays way 'coooler' with tint
so there is no real excuse except for the 'X-factor' ...
its not an answer to your question, but im a function before 'beauty' kind of looney-tic : )
i think i try photoflopping eagle to convince myself
Sorry, there is sunfilm based on static attachment
and you could use it over and over and over : )
when its done i'll show the results ...
ps. i dont think it would be as nice as coating, thats for sure :roll:
coloured windows is a percentage to add
Method and gear used
Check several times and ways before you cut
Watch your hands, the way you pick up, touch things
Use your polses if needed, pollution lurks everywhere
asked a friend or anybody for help to aim
big scissor and tiny pointy scissor, scalpel, felt tip
dont use old blade(s) !! just touch the film, no pressure
8 Pints (4ltrs) of water in 4 stages, with a little soap/dish
Can use the paper from the film to aim for outlines
Keep your hands, film wet at all time (mostly : )
just use your hand to wet the film and window
use a new sponge for that splash, a wiper(?)
use creditcard-o-alike to finish small bubbles
Important, every particle will show so ...
I used 2 pints times 4 during the proces
refill when just under half a pint, due to residu in water
when removing particles, then sponge upside down in water
whip it off
Rearwindow start from the outside
paper not needed, felt-tip to mark outline on film
cargowindow, same thing
For some parts, if you
put the (creditcard) and scalpel together,
the point of the scalpel half a milimeter out
and keep it there
you could get nice edges
You get the idea
Try not to cut yourself ...
If you can comply to the rule "dust and etc. -free
i think it still could keep you busy 4 hours
Have a break every now and then
And yes I f*-up the first sheet
: )have used that for triangular part door...
I dont think people would do this in cold weather
not recommended
Just did the ... CARGO WINDOW ... yeah yeah, think big : )
It was worth every minute, but I wouldnt recommend it : )
If your content with one side
You could save yourself time
using those as a stencil, but ... :roll:
And if you dont have the time and/or are as stubborn as me, go to a pro : )
AND YES, THERE STILL HIDDEN PITFALLS
for you to discover, good for adrenaline, epic ey ? ...
This is the bottemline and my opinion
The film I've used is functional
Take your time to get used to drive around with tint !!
Uh...your signature...do you HAVE to mention your source ?
The story of the pas-mirror, wagondrivers dont look back, (on that side) ...
I'll bet you can do better : ) ...
pff fcuk man, the next thing would be that you have to watch yourself before you inhale that whiff of oxygen ... yo, thats my C02 your breathing
as an result, i say it differs a 10C/50F thats for sure, this tint is ...
Thnx
Cant remember who it was, but tint when sunny ? the way to go ...
its used for other reasons too, thats another fact ...
everthing starts with peace and serenity
then it starts to rumble
Done Processing
note: some bird-goo on the hood (again)
whats with those animals ?
CAN YOU BELIEVE THIS CRAPPY PIC ? : )
My stable
There is one car missing, its red ...
Bam, if so, your quezzy, aluminium factory polish, i'm convinced they are the same, today i'm off to germany, let Rage be the judge...
btw, major fcuk up #2, wind shield, there is a rubber thingy on the mirror
i forgot how easy it is to remove, you should have seen me swet making that cut ...
Dont let me catch you laughing, mfs
