A/C problem.
Whenever i turn on my a/c it blows fine for about 5 minutes but then it looks like smoke begins to come out, it's really white and doesn't have a smell.
It is literally completely oderless and doesn't seem to effect anything, you can barely even see it, but it is pretty noticable if you watch.
any ideas?
any ideas?
just tell me what to do and i'll do it.
whpshhh i sound whipped.
"kinda below the fuelfilter but above the steering rack, and clean it out.
or... look behind the glovebox, above the ecu"
are both these the same hose? if not, should i clean out one then the other?
i might just take it somewhere and have it fixed so i don't end up destroying something.
yep, same hose. sorry, I'm not the best at explaining what is like breathing to me.
If the drain can't keep up with the amount of water being produced, the fan will blow some water through the ducts with the conditioned air. stick something flexible in the end of that hose and ream out the black funky goo (a zip-tie works well)
Wait til during the day when it's hot, and run the ac until it's blowing vapor like you described. THEN stick your ziptie in from the outside and let the pent-up water rinse out the gunk you break loose.
bedtime. g'night.
CRX Type 2 - 1991 -D16A6 Service Manual.pdf
Chapter 22
Service_Manual.zip
never anticipated that 'others' might need the info, me ego-bastard
Here I've removed the canister and its vent hose: That's the hose in question in the center just below the insulation
This is it removed
i really appericate you taking pictures and doing all of that, it was out of the way but i really really appericate it.
good luck with it.
any other ideas?
that box? the pictures 56k friendly but too big to post here.
check your windshield if there is any signs of residu...
Time of day relates to air humidity
residu relates to possible leakage, check looking glas...
nope im not an expert...is there a doctor in the house : ) ?
closed, ac on, condense in no-time, it was pretty funny, i stopped,
i thought, oh heavy fog,
