D16W7 engine
ok i found that this engine is pulling 160 HP. here is the info:
D16W7
* Vtec-E
* Found in:
o 2005-2007 Honda Civic Vti-L/ Vti (Singapore)
+ Displacement:1590 cm3
+ Compression : 10.9:1
+ Power : (*160) hp (130 kW) @ 7800 rpm & 108 ft·lbf @ 7900 rpm
+ Valvetrain : SOHC
+ Redline 8600RPM
+ Limit 8900RPM
+ Fuel Control : OBD-1 MPFI
+ ECU Code: PM12
my question is if this engine can work w/ our 4wd system and since is a d16 engine does the mounts have to be modify in order to make this engine fit?
D16W7
* Vtec-E
* Found in:
+ Valvetrain : SOHC
+ Redline 8600RPM
+ Limit 8900RPM
+ ECU Code: PM12
perplexed
I want optimal HP (&torque) while retaining my AWESOME fuel economy.
I currently have a ZC/d16 SOHC with V-tec,
it has a DX tranny (synchros going out slightly, maybe), and I LOVE the gearing in it. I have no doubts this tranny can do 140 +, no argument.
catback, resignator, glass pack, high flow cat
Adjustable CAM
Apexi Vafc
cold air intake
Anyways, removing weight is an option, but it already has no PS, (duh) and all AC components removed. Spare and jack are temp solutions. If I have 2 ppl in the car m limited to what I can do with weight, so moving on.
What can I do to make this puppy fast in the moment and economic at the pump?
remove the back seats and the trunk carpet, spare tire, jack. if it's your dd and you still want it to look decent interior wise then i dunno what to tell you
mpfi swap, done
cai = aem
d-vac??? This might be something to look into!
Im thinking about going MSD ignition and high performance Plugs/ wires, more high performance than now
Might extend the CAI to where the resonator used to be, its colder there
seat upgrade isn't in the wish list yet, too many other things
i suggest taking a serious dump, and not eating before you drive. dress lightly, or just go naked. shave your head bald, and all the rest of your body while you are at it... simple weight saving tactics
i just know it as "d-vac'd" you remove vaccum lines from the car and other things, post a topic maybe someone has some experince.
