timing belt job... worth it?
well, recently my cars timing went out of whack, dunno how, prolly jumped a tooth or something but anyways... i decided i might as well get a new timing belt job, as i have 110K miles on it and no idea if the belt was changed ever before i bought it at 97K miles (most likely not..)
i called the Honda dealer today to get a price quoted, and they said $475 :shock: that includes new timing belt, alt. belt, water pump and then they set the ignition timing and valve clearance as well... (i do have, however, a 15% discount though, but still thats $400...)
my question is, is it worth paying for it, or should i do it myself. i am a little nervous doing it myself, even though i have the Haynes manual and everything.. also in the end i would end up paying like $150 for new parts like the belts and water pump. also it would prolly take my a few days to do this, and a TON of headaches. idk anywho....
anyone have some advice?
oh lawdz :?
the timing belt was only 20$ at autozone so i dunno why yours is so overcharged.
That being said, local mechanics are significantly cheaper. But they might suck and you have little recourse. If you can find a quality legit local mechanic, they are worth their weight in gold.
Now...the question if it's worth $400.
You have to ask yourself: What is your personal time worth?
When I was younger, with more time than money, I'd be inclined to try it myself.
Now that I'm older and [sarcasm]flush with cash[/sarcasm]...the prospect of spending a whole Saturday changing a timing belt is not appealing. Or even realistic. I'm way too busy.
i would never buy anything other then a Genuine Honda belt when it came to something this important, $32 is half the shelf price. i checked Advance auto's website and the belts were all $30-50.....
exactly man, i feel the same way. problem is i have no money, for this, haha... but i'll be needing my car. i've been really studying up on my manual, and im pretty sure i'll be fine. except, what if it goes wrong, i'd rather spend a few extra bucks and have it done right the first time.
but, even dealers dont always do things right... at least not my local one
:x hahah ah well... i'll see if im feeling up to it when i come back in September.
thing is, for $475 i can get a whole "new" motor from Japan with only 30K miles on it and VTEC
1 - Buy the Honda water pump. Chances are you'll be changing out the Autozone water pump in 6 months when the front seal starts to leak, and it's like doing the whole timing belt job over again (timing belt has to come off to change the water pump).
2 - Swing by a local garage before you start the job, and slip them $20 to crack the crank pulley bolt free with their big impact gun/compressor, then zip it back on snug (not too tight) for your drive home. This will make the job 1,000,000 times easier.
3 - Make sure you have a 1/4 drive deep 10mm socket to get the timing belt cover bolt out of the center of the cover by the timing belt tensioner. Chances are a 3/8" drive will be too large in diameter to fit the hole in the cover. The bolt head is recessed into the cover.
Not hard a all.
The other thing to consider is whether you are going to do the valve adj. later or farm it out to a garage.This would be a good time to learn how to do the valve adj.
Try cracking the crank bolt first.Mine came off easily.Even the crank came off easily too.
Go ahead and get a good D16.. It would be the same price as getting the dealer to do it, and prolly a few hundred times easier.
i'd never be able to find a good D16 thats even half as good as my ol' D15. its only got 110K on it. and its definitely not easier
While you have the chance, do the mpfi swap.
The standard timing belt service from Honda is normally, belt, tensioner, waterpump, crank seal, new crank bolt and belleville/spring washer.
Oh and a Honda technical service manual is priceless, I had a Haynes and later opted for the tsm.
Good luck ma man
soon as i gt home, the wagon will be under the knife, haha... new timing belt, new clutch.. it will be nice
oh and you dont have to juice up the waterpump seal with hondabond for it to seal. the rubber seal thats on it does just fine. if theres some build up on the sealing surface take some emery cloth or some fine grit sand paper and go over the surface lightly.
good luck man hope the rubberband changing goes over smoothly
Well it's not that bad. It took me (doing it alone for the 2nd time in my life), about 2hr and 40 mins. It wasn't my shop though. So i spent a 1/3 of the time looking for tools. Suxed :x
Anyhoo when i did myne, its was a tooth off. The crankshaft pully bolt was loose!!! I use a wrachet to get it off! (With a little muscle). I drove about 11,000mile on a bad timeing belt!!
Thats why it alwas threw those ecu code, and had no accel, verry sluggish,backfireing, ect. Its amazing what timeing can do.
Im happy now it has a little pop now and with a new clutch it moves.
i set the cam at UP and lined up the two marks, also set the TDC at the arrow...
put it back together, starts up fine. drive it around the block and it starts running shitty..skipping really badly and what have you, also throws a code 4 (crank angle) and basically i cant drive it.
so i take it all apart again (this time in only like an hour, haha) and redo it. spent like 2 hours just making absolutely sure that TDC was correct and the cam was UP. put it back together (also with a new Alternator this time... different horror story). crank her up, and drive around the block. it does so beautifully. so im super happy that i finally have my car "back" after 3 months.
first day of school, im headed into Savannah.. 30 minute drive. 20 minutes into it it fricking starts skipping again. luckily i made it to school (BARELY in the end). well, 2.5 hours after sitting in the parking lot she starts up fine and i make it home without problems.. though its definitely not running perfectly anymore.
at this point i am super pissed. if my timing is off, why doesnt it run shitty in the first place? why does it only after a while... and mostly WHAT THE HELL is missing?! why the hell is it still off?!
what am i missing or doing wrong.... :x
The Helms (factory service manual) says to do it this way, but they say to only rotate the crank for 3 teeth on the timing belt.
thanks
Adv and retard to see wich way make it seam to run better then get back to the belt and see if it need's to move a tooth one way or the other.
And or if could be something with the MPFI/ecu?
