Rear hub bearing replacement - suggestions ?
I've reached the point where the rear hub unit bearing in my 4WD wagon is shot and has to be replaced. According to the factory manual, it takes a lot of dealer-only tools to press the bearing off the trailing arm. Is there another way, or is it time to head to the local Honda dealer with a jar of vaseline ?
Ghetto Way:Remove the snap ring to the brg.Actually what you can do is place a large mtl dowel or a very big socket on the brg & press it out with your PRESS.Later you can use the old brg to press in the new brg.
