Stock tire size question
Does anyone know what the stock tires were on a '91 EX sedan? I'm changing to 14s and want to correct my speedo somewhat. As of now it reads 5+ mph high with the 155-13s on. Also can you point me at an online tire size comparison chart, please? I must not know what the correct term is to search...
stock tire size for the EF 14's (Si, EX) are 185/60/14
tirerack.com is a good source for finding stock tire sizes as well.
I may run a taller aspect ratio, even a LT tire to fill the fenders... I don't really want a wide tire- this car is about economy, so less contact patch is good.
http://www.miata.net/garage/tirecalc.html
:? The reality is that there is up to a allowed 7% difference in tire specs between tire companies.We use to find 1/2''(12mm) -1''(25mm) wider thread wides in the same size tire.
