(DIY)Antenna replacement
When you end up with something like this...
Antenna broken, cable ripped apart
Get yourself:
Bicycle standard brake housing with inner thread
Make sure you get yourself plenty of length
AND
Wire about 1.8mm, combination plier and energy
cut about an inch 3x
I started from here, removed the inner thread, outer housing nipple first
Find the hole, I had to chop the cable back and forth a couple of times
THEN:
Feed the inner thread downwards
hold the other end then pull back the housing
Use the 3 pieces of wire to do this, wrap round and squeeze gently
make sure its rounded to avoid scratches or use tape.
Chop chop again - gently....but firm
G reat succes, the new antenna.
You can use this method also for audiocables and such under your carpet
Get yourself:
AND
THEN:
wow... haha.. great write up man! :P
Whaaaa...love your optimism...local...almost NO O O O O O, shuttleparts...
Until now I get the rear-end of the donkey when asking...
Thanks...
:roll:
-you're welcome :roll:
Like the fuel cap is registered wrong here in every car-base-related computer...
and yeah...dont ask : )
you have my compassion dude
Nice write-up, keep 'em coming!
Likewise Hay..., likewise : )
...you bet
