so you think you only have a small rust bubble?
well, look again... i was raising my car up a jack a few days ago and my hand felt under the side skirts and went through a hole :shock: i decided to investigate....
the only visible rust, a 1/2 dollar sized spot that has been temporarily fixed:
the top part of the wheel well is clean... but then there is some surface rusting along the lower part and behind the trim piece:
also in the door jams there were rust holes around, of all things, these plastic tabs that say "Ziebart Rust Proofing" (either ironic, or bullshizzle is what that is)
lastly, i took off the side skirt and Voila!! the bigass hole...
:x :x :x :x :x :x :x :roll:
so you think you only have a small rust bubble? well, look again.
That sucks man.
can you see the little spot on the wheel well?
here's what had to come out
you guys outside of the rustbelt are so lucky, you don't even realize
