I was wondering if everything here is what i need with my dual cam ZC swap.
I mean I know i need the PM7 ecu but i was going to buy everything if it would work. The engine harness and the MAP sensor is what i don't know about.
the ZC intake manifold will NOT bolt to a SOHC D-series motor. the header will. or at least, im running a header that was on a ZC on my D15B2 haha.
engine harness from the ZC will plug directly into the chassis harness of an RT4WD. all the sensors (MAP, EACV..etc) are the same for all MPFI motors, pretty much.
