engine is going bad
ok guys im retarted about swaping engines and i dunno what engine do i wanna put on my wagon. i have a 90 rt4wd automatic and the engine is goin bad( is stock d16a6 engine). i want to know what vtec doch will fit in my wagon w not that many mods. im also planning to swap the tranny to stick if i get another type of engine. what do u guys recommend. im plannin to invest around 1000 bucks on that swap, both engine and tranny. please help. also plannin to turbo charge later. thanks guys
if i were you, id get a DOHC ZC swap, 1.6 L 137 HP non-vtec, 7200 rpm redline, etc. its still a very good engine and a direct drop into the stock everything on the 4WD wagons. no wiring, mounts, etc needed.
you can find these for cheap too, usually $400-800 bucks.
if you are just going to swap motors you can keep everything original.. gosh this is such a deja vu, i just discussed this with someone else.
check the stickied links at the top of the engine & drivetrain forum.
sorry to threadjack, astuto :oops:
wagon 4ever.......................
Mhinkle- Most drag cars are automatics..
There is a lot of supras that are automatic.. Think about it.. You will never loose boost with an automatic.. You don't have to let off to shift, you keep it mashed to the floor so it is going to keep spooling.. etc..
BTW-
You aren't going to put anything other than a D into your wag for $1000.. Hell my mounts alone were $500..
actually the engine was ok. the mech was a retard and told it was bad. i still plan to swap a jdm dohc zc on her and the tranny will try to get from thedoodle he has one. i just have to save money. now right now the swap to stick is my goal. after that im pretty sure all the stuff will get easer.
