New to site/Pics of my first wagon
Its a Light Blue RT4wd Wagon with 140,000 miles. Runs great but needs clutch, pass fender, rear 4wd panel, and pass marker.
This is the part that I need
Will get better pics tomorrow.
    i could prolly get that metal corner piece if you need it ;)
    p.s. lose the hubcaps :?
  • michaelhinkle1michaelhinkle1 Senior Wagonist
    it kinda just looks like surface rust, it doesn't look like it's ate through much.
  • Okiewagon1Okiewagon1 Wagonist
    I have been through all of the major areas that tend to get rust and I have found none. The only rust is surface from someone starting body work and not finishing the work.
    P.S. I have found a pass fender and that rear panel. What I really need is the pass marker light next to the headlight.
    you mean the corner light? if so, i think martin (wagodizzle) has some fresh corners, pm him.
    Yea, I have pm'd him but I am working on a deal for the edm clears and amber tails from gutterslide or something like that
    I think martins are from a 88-89 which are different than my 90-91 right?
    yeah the 88-89 are differnt then the 90-91.. also though they have been sold ;)
    all you need for those corner lights to work are the plastic pieces that go on the fender.
    yea I know but I dont really care for the screws in the markers. They are sold anyways. I did the same thing on my crx until I could find the newer ones.
    Metallic Blue... gea...
  • Just an update guys. I have added front mud flaps, new color matching fender, usdm marker light (that is until my package arrives from gutterslide), pass side mirror, removed the engine and detailed every nok and cranny, added aem cold air, nology wires, new cap and rotor, new Oem steering wheel emblem, new shift Oem knob, Oem roof rack, and drive side window regulator. O I also put in new head gasket, main seal, spark plugs, oil, tranny oil, coolant, all kinds of seals in the motor. Adding a couple of missing parts that I was missing in the interior like broken air vents and missing locks, and broken seat tabs. All fixed now.
    I will be painting the car sometime this summer still just trying to decided what color to go with. Thinking of stock color but I dont know.
    time for some new photos 8)
    did you burn those hubcaps? i mean, c'mon speed racerrr, those hubcaps give you atleast 60 more whp. :wink:
  • yep. I have some 16in slips black in color. O yea I lowered the car as well. What a pain in the a%%. I have ef shocks with coils in the front and ef shocks with da lowering springs in the back. I still need to try and cut a coil or two off the back.
  • UPDATES:
    I now have EDM tails and Corners (thanks gutter) and I just bought a yakima roof rack.
    Cant wait to install.
    Its been sometime since I have update and I have come along way. I will take the next couple of days to bring you guys up to speed.
    EDM Corners
    EDM Corners Installed
    New EF Hatch Lip
    New Pass Side Mirror
    Cleaned up a bit
    Yak Rack
