Any AC Techs out there? or just really experienced owners?
Got a dilemma, need some advice.
My buddy is admittedly a little out of his realm with the AC in my 90 wagon. He attempted to recharge the sytem after it hadn't worked in the 3-4 years i've owned it and who knows how long before that.
Before that he replaced a defective sensor and the dual switch as well as replacing some wiring the previous owner had cobbled together that looked like it had melted. It had been converted over to to accept 134A.
I wasn't too confident in the thing being intact after all this time but he was all excited to get it working.
So he's charging the system after first putting in that Neon green lubricant which he explained would make it easy to identify if there were any leaks in the system, he also explained that the compressor would not fire up until the system had a minimum amount of pressure in it.
After the 2nd or 3rd bottle installed, the compressor did fire up for a little while, but then it stopped working.
he continued putting in refrigerant thinking the system was just completely empty after all this time and needed to be completely filled and purged of air.
The compressor never came on again and after the 4th or 5th bottle, he put his pressure guage on and it showed that the system had lost all pressure. The strangest thing is that we have yet to see any leaks or green lubricant anywhere.
Anyone got any ideas on what is going on here? Or are there any particular failings common to our era Hondas AC systems?
so im sure a humble little civic needs only like 2.
you definitly are leaking somewhere man. hope its not inside your car! check behind the dash for green stuff.
I'll pull that evap core out and see wassup.
Keep you all posted.
