Amp kit help please!
Just bought an Amp kit.
This one to be exact: http://www.walmart.com/catalog/product. ... id=4694327
It has a thing that goes on the battery post. How do I wire it? Do I cut my current wire going onto the post and wire it into the Connecter that came with the kit? I've read the directions but it just is not detailed enough. If anyone has used this kit help me out! the capaciter is kind of confusing as well. Pics of the thing that goes on my battery terminal are below so you get a better idea of what I'm talking about.
Thanks in advance! V V V Pics of everything.
i believe so. if i see the pics correctly it looks like there are 2 holes to put wires into on that terminal.
DISCONNECT POSITIVE AND NEGATIVE BATTERY TERMINALS BEFORE STARTING AND LEAVE THE NEGATIVE OFF UNTIL YOU FINISH ALL YOUR WIRING.
This will help prevent you from shorting out the car electronics if you hook somehting up incorrectly.
there is only two speaker wires coming from the box so i'm guessing they go to both subs so both subs are running via two wires to the amp.
thanks for all the help boys!
better pic of the connector i need
The missing connector from the head unit is going to be specific to the manufacturer of the radio. I would do a search using the model number on ebay to see if you can come across a used one.
Here is a link to Crutchfields amp installation page, they are pretty good and you also might look there for your missing connector depending on how old the stereo is. There is also some good info on hooking up the capacitor.
http://www.crutchfield.com/learningcent ... guide.html
is the amp i have
"Number of Channels : 2
Rated Power
85 Watts x 2 @ 4-Ohms
125 Watts x 2 @ 2-Ohms
250 Watts x 1 @ 4-Ohms (Bridged)
Total Power : 250 Watts
Maximum Power : 750 Watts
Bridgeable : Yes
Crossover Controls
High-Pass/Low-Pass/All-Pass
Variable from 50Hz - 500Hz"
would the cap make it sound better? it sounds pretty good as it is imo.
the green on light is on, the protect light is off, thats good, right?
thanks to everyone that helped.
underneath where im supposed to put all my speaker wires it says "bridged" and a (+) sign on the far left and on the far right a (-) sign. thats where i put my wires. i have it set on low pass and it hits smooth it still has a few boggy sounds here and there when it hits though. i have a really good battery it was around 80$
what do you mean mono? and how do i bridge the amp? or did i already do that?
and yeah, the subs are the only thing on it.
and as in deep bass etc, the more i'll notice the difference. did you mean it'd sound smoother? or hit harder? or what? details, please.
and thanks again man.
