Windshield Washer
I replaced the hood on my 89 wagon a few years ago and the washer squirts the cleaning fluid too low on the windshield to clean the upper areas properly. I tried to move the nozzle thing by sticking a paperclip into it, but it won't move. I didn't want to break anything, so I didn't try to force it. Is this a good way to do this? Any suggestions?
Anyway hope this helps you should be fine if you can get enough leverage with a paper clip and it doesn't break off in the nozzle :shock: .
Part of our LOF was to adjust the nozzle's so I can say this method has been tested repeatedly
it could just be that the nozzles off the current hood (assuming you didnt change them) are old and clogged full of crap, buy new ones they're not much and probably need changing anyways.
the nozzles take maybe 3 seconds to remove. they are held in place by a "clip".
pop your hood open and look at the bottom of the nozzles. squeeze the two black plastic bits underneath (kinda like a clip), push up and the entire assembly will come out (from the top of the hood).
you have to unplug the hoses, of course.. haha.
arn't they black? atleast mine were.
