main relay location
edit:
found it.
for future notice to anyone who needs it.
look inside the car, down where the brake pedels etc are. look to the left of the fuse box (right since your facing it) it has ONE 10mm bolt holding it in. it looks like a black box with brown on one side. it's eaiser to remove with the fuse box unbolted, pull slightly on the trim below it and remove the bolt disconnect the plug and play adapter and shimmy down the relay.
heres a picture of it:
found it.
