Car starts randomly
Yesterday, it was really humid and hot outside, my car would start for a few seconds when I used starter fluid.
If I didn't use started fluid, it would just turn over and over and wouldn't crank.
This morning it's around 55 degree's, and the car starts fine.
Would this be a main relay problem?
yes!
i used to have an accord that would not start unless i parked in the shade.
ps. you have a lemon.
lemon?
and how much are main relays? and does any 90 civic fit?
lemon denotes a car that has endless problems, haha.
and thanks i found a main relay, autzone 40$.
is that too much?
is this the right part?
http://www.autozone.com/R,APP1233871/ve ... Detail.htm
Here is the prof!!!
http://www.hondacivicwagon.com/board/vi ... php?t=3518
this is what i did, and so far no problems. well, twice... but those dont count. haha.
i'm just going to drop the risk and buy a new one since i'm driving all the way to the beach and back this summer (around 400 miles there, so 800 round trip)
i'm just trying to work all her bugs out, would the main relay be the reason my ecu is throwing the code 16? and the problem isn't my injectors?
after that i'm replacing the fuel filter, dropping the gas tank and taking it somewhere to have it cleaned since im sure an 18 year old car has a lot of shit up in there.
there, i said it. i do it with little clips all the time... usually i do buy something though. i bought a coil spring for the 88' mazda wagon last month (75$! used) so i treated myself to the digital clock out of the donor 88' mercury tracer. seemed more fair.
lol, i do the same, sometimes... the entry fee is $1 to the yard, so i help myself to a couple emblems here and there to compensate the fee.
if so, i'm going to pull-a-part.
wheres my main relay located?
http://www.fourthgenhatch.net/mainrelay.html
btw, that website has a LOT of good DIY info
so i acess it via the inside of the car?
so if i replace that should my ecu stole throwing cels?
ok, but i remember reading whenever it's throwing code 16 is was either your fuel injectors or main relay.
that's why i was asking.
oh, ok then. i'll go to pullapart tomorrow man.
creepyyyyy
When I got my 4WD waggy, I re-soldered main relay ...
