brake pedal falling to the floor..
When I drive, and I hit the pedal, sometimes it will fall quickly to the floor and one of the front wheels will lock up until I let off the pedal...
Would I need to replace the master cylinder? It does the same in the rear at times also.I haven't opened the brakes up, so I don't think bleeding them would help
x2, happened to me.
buy a new master cylinder, replace the old one, fill it up with fluid, bleed out the brakes, then replace the fluid again and you're good to go!
An easy indicator of a bad brake master cylinder is seeing any fluid or peeling paint on the brake booster - if you've got that then you need a master cylinder, but that's not to say other issues couldn't also be contributing to the low pedal as well.
