A/C setup Diapgram..
Well since it is getting hot outside I think I'm going to re-isntall my A/C system..
Does anyone have a diagram of how it goes back together? I think I could figure it out but I'm being lazy and don't want to.
haha dude, thats awesome. my friend i once talked me into driving butt naked... went from Tybee Beach into downtown savannah. had my shorts at my legs just incase we got pulled over. great times.
i did it back when i was 8. no comment, doodle.
I've driven naked before.. but not because I was hott...
you need to entire wire harness from the AC unit (pictured above). the harness runs into that cabin where the AC lines do. the plug for it is sitting behind there under the dash.
Also what are you going to put back in the system. R-12 (hard to come by and $$$) or R-134. Just about everywhere.
First off get a new receiver dryer. This absorbs any moister out of the system. And if you left it out and the hold exposed its not reuseable.
Umm once you have everthing installed. If you have the tools to do so. Apply a vacuum on the system. This will pull any moister and air out of the system (thus you have pure refridgerent). Leave the vacuum for 15-25 min this will let you know if you have a leak if theres a drop in vac.
If all is good. Rechare to spec.
If you dont have the tools go your shop or any ASE Certified shop and have them fix it up.
Here a Stock wagon A/C wireing daigram posted on
http://www.hondacivicwagon.com/bb/viewtopic.php?f=10&t=6149
ANd heres the one or as close to the A/C wire i got for the B harness.
