fuel pump location
since i posted this in a PM to some guy, i figured i might as well make this public for future reference..
this car is a 2WD model with the D15B2 engine.
anyways, this is the location of the infamous fuel pump. under the back seat lower cusion.
well here you can see the seats folded up and the vinyl covering peeled back...
here you can see a closer view of the fuel pump cover..
excuse the mess
excuse the mess
On my 4wd I have two covers. See the round section of body to the left and up of that which has four indentations ?
that's where the second cover is on my shuttle and the fuel pump is under that cover.
On the CRX you have to drop the tank, you can only remove the sender unit. I figured the hatch and saloon were the same unless they have the two openings?!?
We only got a D16A6 on the 4wd.
The 2wd was a 1.4 twin carb car.
USDM 2WD = D15B2, dual-port PGM-FI
USDM 4WD = D16A6, multi-port PGM-FI
is it an EDM (JDM??) thing only to have a second cover over the tanks on the 4WD? i thought the 2WD and 4WD shared gas tanks... so that would mean the USDM 4WD didnt have the second covers... or?
USDM 4WD guys, chime in!
