DA Tokico 1" drop set-up on 4WD waggy!
Tonight I've put front suspension togther on my waggy.
WOW - I thought it would be lower then before ...Boy was I wrong!
THe front settled at 24.5" (floor to fender), before it was barelly 24" on each side(wich translates into 13.5" from hub center to fender)...
I'll try to finish rear, but its getting late :roll:
There is a link to eBay page where I've gotten them from!
http://cgi.ebay.com/ebaymotors/TOKICO-HP-SHOCKS-SPRINGS-ACURA-INTEGRA-90-93_W0QQitemZ180232218901QQcmdZViewItem
Heres a shot (I'll get better ones lil later) of completed rear. It sits freggin level or a bit higher than stock 4WD rear ...Difference between FRNT and REAR is wooping 1.5" :shock:
I am sure it will sag a bit...BUT ... :shock:
Drives a lot better, firmer but not too agressive...
Front is almost perfect.
Rear is a bit too stiff.
I'll have to alter rear coils a bit to level it out a bit.
Overall I am very pleased with set-up...
Cheers!
The rear sits as if not lowered :shock:
I guess I would have to alter rear coil height to level it up...
As of last night I put old stuff back in rear department, at least it sits level ...
Thanks !
