2WD vs 4WD fuel tank?
According to Majestic Honda fuel tanks for the 2WD and the 4WD wagons are the same. Can anyone verify this?
I have a hole in my fuel tank right now, and there is a 2WD in the junk yard I may be able to get the tank from. If it is the same Ill take it, but Im not totally sure it is.
Anyone know for sure?
Its going to be a dirty weekend under a wagon the junk yard me thinks.
On carb CRX tanks I know the space is there but it's not a blanking plate, Honda never cut the hole.
Frikkin wierd if the 2wd tank has a space for a prop shaft!! But I guess it makes sense to manufacture less parts.
If I can just unbolt a cover and dump a fuel pump into the space on a 2wd without any cutting that would rock.
