"Rivets" for roof rack?
I took a wander through the local junk yard, looking for some small parts. Its pretty rare they have wagons at the one I usually go to, but this weekend I found one. A Blue/Gray 2wd with an OEM roof rack. So I unbolted the roof rack.
Once I took it off, I cut out the roof liner (it was in terrible conditon anyway, dont worry) and check out just how these things Bolted to the roof anyway. From what i saw, its a "rivet" type of pecie that goes through the factory sheet metal, and is threaded on the inside.
Now for those of you who have installed OEM or non OEM racks that do not clip on and have to "bolt" in, were you able to find these Rivets at the local hardware store? What are they called?
Last, if anyone has a factory isntalled OEM rack, can you take some mesurments of where it is bolted up? I didnt think to take them while I was there. If not, i can go back next weekend and see if its still there, but its costs me two bucks each time lol. :roll:
to do this best you'll prolly wanna lower your headliner, which is easy. you just need to take off the grab handles, dome light etc. then pop out the plastic trimming along the top.
about the location.. here is a pic....
the front bar basically lines up with the B-pillar. i now wish i had moved it forward a bit... but anyways. this is the OEM location :P
Hopefully the car gets painted soon. Once that goes down, its rack time!
I used metal screws with rubber grommets to keep the water out. The roof hasn't leaked yet.
In the end probally going the Wagodizzle way.
thats dangerous
....remove the headliner.
http://www.acument.com/avdel/tsnutsert.asp
i jsut came from the junkyard and found a subaru wagon roof rack. i tried it putting it on the roof and its perfect. my concern is where can i find a blind revit nuts nuts. thsi rack uses 4 on each side total of 8 bolts.
somebody direct me to where can i get this blind reivt nuts.
thanks
wagon.....................4ever
http://www.harborfreight.com/cpi/ctaf/d ... umber=1210
I used the fancy hydraulic one we have at work, but If I didn't have access to that I'd buy something like this^.
