Rear Window Wiper
The rear wiper on my 89 RT4WD wagon is lame. The arm apparently is too weak to push the wiper blade down flush to the glass, so it is bowed out and only makes contact near the ends of the blade, leaving the area covered by the middle of the blade untouched. Do I just need a new blade or is there an issue with the spring in the arm mechanism? Does anyone know how to fix this?
if you want i could check my local yard.. wiper arms are about $8 or $9 over there.
